pseudomike
Ok guys, please help....
I have an old 3/4Ton GMC that I am almost done doing a frame up on.
I've replaced every body panel, the cab, springs, motor, you name it. It's been a lot of work, and it's getting close to done...except for some gremlins...namely the wipers.
I bought a bare rust free cab from a guy for the project, it was bare so I transplanted the entire wiring harness out of a'91 Blazer into thes truck. I mean every wire, including injection, pwindows, cruise, A/C...every single wire. It's running the '91 gauge cluster, the '91 column, all brake switches, sensors, motors, even the rear ABS unit. So on the weekends I have been assembling this truck and so far so good. The truck started and ran, the headlights work, A/C, dummy lights, cab lights, interior lights and so on.
Then, this weekend I goto hook up the wipers and well that is when it got interesting. The wipers are the delay type on the column, no external switch..and the story is that when I flip them on they work, low speed, high speed. The washer works, but the delay, well the dealy has a mind of it's own. It never really delays, sometimes high speed sometimes low...sometimes they won't even shut off until I put the switch back into the low or high speed position. And the washer, yup it washes...but sometimes the wipers just stay on. So I tried changing the motor aout and it is the same problem. I'm beginning to think I need to dig into the column and replace either the delay module or the switch under the steering wheel.
If someone has a simpler check, or knows a good way to troubleshoot this please let me know...i'm trying to wrap this thing up before the snow flies and I have enough to do without these little things holding me up.
I've replaced every body panel, the cab, springs, motor, you name it. It's been a lot of work, and it's getting close to done...except for some gremlins...namely the wipers.I bought a bare rust free cab from a guy for the project, it was bare so I transplanted the entire wiring harness out of a'91 Blazer into thes truck. I mean every wire, including injection, pwindows, cruise, A/C...every single wire. It's running the '91 gauge cluster, the '91 column, all brake switches, sensors, motors, even the rear ABS unit. So on the weekends I have been assembling this truck and so far so good. The truck started and ran, the headlights work, A/C, dummy lights, cab lights, interior lights and so on.
