wire in seatbelt?
digity
Brentwood Ca
Ok, I'm putting in new LMC seatbelts. Did the front passsengerside with no issues. Now the driverside inside strap (male end) with the plastic sleeve. I unbolt it to find a black wire. :confused: What is this? It wasnt bolted to the bracket for a ground it just runs up the sleeve. Tried tugging on it a lil. with no luck. It runs down under the truck somwheres havnt looked under yet. Any ideas what this is?
It run under the carpet, back up to the fuse block, its for the seat belt light / buzzer.
It's called "an extra part."
I removed the same wire when I redid my interior.
