Ok so I am still working on my ezwiring 21 kit.. getting farther though...
anyway... I got most of the under hood wires done.. headlight harness is done and tail light harness is done (less 1 wire)
but I want to try and get this thing fired up by next weekend.. so I need to get the engine harness done and inside cab harness done..then I can care about tail lights and front clip wires...
but anyway..
the last wires for me to run are
1. distributor power wire
2. power wires from starter
now I know that one of the starter wires is a heavy gauge wire (biggest in the kit) and labeled (52) solenoid power. So this is the big power line that will feed power to the fuse block.. I get that...
However there is a small wire.. I know it is the ignition switch wire... their own book says so...
IGN Sw Start = Purple to starter. I went with the all black kit and I just dont see a wire at all that says IGN SW Start. What wire would it be that I need to run?
im figuring it is the ignition switch which is on the column and I just dont see the wire.
can anyone assist?
I have been building this harness in my kitchen so far.. but by this weekend I want to get it into the truck... and start looking at getting it prepped for running....
so big wire gets power from starter to fuse block... THAT IS GOOD!!! lets get some juice going.. but I will have no cranking....
also I have a stick and remember that I had 2 wires (when I had an auto) and when we went stick..we jumpered them (neutral safety switch).... I have no clue where that wire even is on the new harness... anyone that did a ez kit remember?
Jeff
wow... seems that the obvious can be missed... I re read their book and it never said where the wire was... although I read the front cover..
something about this line didnt seem right..
2 pre wired gm column ignition switch plugs
so i looked at them and the ign switch wire is there... grrrrrrrrrr
i think it is time to sit back and drink a few beers....
but anyway..
can anyone assist?
Jeff
