85mudblazin
Thanks for the info guys, ill figure it out tomorrow......err today
Did it just like this and it works good. Not to mention my bling bling light I added to my switch panel468k5 said:The way I wire mine is from the stud on the back of the alt. I run a heavy wire to the 12V constant side of the starter or directly to the + side of the battery. And on the two wire plug , the bigger wire also connects to the stud on the back of the alt., the smaller wire runs inside the cab and connects to a light (I use a red one) that I mount in the dash. The other side of the light connect to the 12V+ key on side of my ignition switch. The alt. acts as the ground. flip the switch, the light comes on, start it, alt starts charging, light goes out. I've read somewhere about using a resistor instead of a light, but I prefer the light. I used to have trouble throwing fan belts and wouldn't know it till the engine over heated or I run the battery dead.
I've also heard that you can run without the two wire plug but the engine has to hit something like 3,000 RPM's for the alt. to start charging.
If this doesn't make sense I'll try to find pics.
Hope this helps
This was the ONLY nunrusted piece and it stood its ground.onetonbb74 said:... just rip it off by moving it back and forth until it breaks all it has is a tab that bolts to the bellhousing bolts.
..my 79 C10 has 2 sets of fusible links now,one OEM set from the original six cylinder harness,and another I added in from a donor truck,so they can reach the battery cable..and I could replace all 4 of them without crawling under it (and without cracking the solenoid cap in peices)if they ever meltdown..
