wiring diagram for 1987 c-10 305/700r4 at the firewall
sweetk30
Back to play nice .
in the back of your brain
looking for a diagram for the 1987 c-10 305/700r4 at the big plug on the firewall .
i am trying to separate the tbi harness from the gauge/starter wires .
since i am going holley sniper and dont need the massive tbi wire pack anymore .
EDIT : here is what i got to figure out .
pink / black tracer - goes to main tbi harness .
purple / white tracer - goes to main tbi harness .
solid lt brown - goes to tbi main harness . and no not the alt wire i got that one .
tan / black tracer - goes to tbi main harness
BIG pink - it goes to TBI coil plug . so i think its key hot and crank . ?
tan / white tracer - this is on the 2 wire oil pressure sensor top of engine behind intake .
orange - this also is on the 2 wire oil pressure sensor top of engine behind intake .
light purple - its going to the 700r4 trans plug .
just to be clear i have the comon known oil pressure gauge single wire . its light tan/orangish .
all ends were labled before i pulled this from the engine . as i had unpluged the main harness at the firewall block when body was pulled .
Just did the same with the diesel harness today. Basically I removed everything but the three plugs for the wiper/washer, and two big red wires and purple starter signal.
Figured you were removing everything that wasn't on this block. I'm not very well versed in the TBI world to be honest
keeping factory dash / senders / gauges / basics to run . ditching the tbi stuff to clean it UP BIG TIME and trying to do it nice and neat so i can try and get a few bucks in the for sale section for a tbi harness labled / as complete as possible .
then tie in the MSD dist wires and the holley sniper unit .
