If an electric fuel pump loses power while the engine is running, isn’t the injection pump generally capable of continuing the fuel supply even without a fuel pump?
The reason I ask is that I always hear people saying to wire the electric fuel pump to an oil pressure switch so that if oil pressure drops, fuel flow also stops. Generally there are two reasons for this fail-safe: 1) cuts fuel in case of a crash (so fuel doesn’t flow everywhere); and 2) in the event of engine failure (e.g. extreme loss of oil) the fuel supply is cut to prevent running the engine without oil and ruining the engine.
If the IP is capable of powering the engine even without the fuel pump running, reason #2 doesn’t seem to hold water. Am I missing something?
