wiring harness help
muddybuddy
1 ton status
Northern, VA
im collecting parts for 6.2/4L80E swap into my k5. i bought the computer for 6.2/4L80E combo, but i still need to find the wiring harness. do i need a wiring harness for 6.2/4L80E combo, or can i get a harness from 350/4L80E or 454/4L80E? would a harness work from a 2wd?
a harness from a 2wd should work, your best bet is to get the ecm pin outs and double check every wire
i would say no, if you get a injection harness for a gas engien there are going to be a lot of wires that are not needed
