Pulled my column and replaced the blinker assembly and chase down some burned up wires. Well I need to replace a few that go all the way to the fuse block.
Since my search ability sucks...
How do I remove the block far enough to get it apart.
I unscrewed it from the firewall but without having a decent diagram or a write up to read, I don't know how this thing comes apart.
I think it used to be brown
This is from one of the plugs that goes into the top of the column about half way down.
I can trace this burned up wire all the way behind the fuse block.View attachment 123401
This is from one of the plugs that goes into the top of the column about half way down.I can trace this burned up wire all the way behind the fuse block.View attachment 123401
