My daily k10 has 4.10s. High gears are for cars. With the 6.2 700 and 37s it needs gears to work
4.10:1 is the ratio that I would run in that combination, too. It's the running 4.56:1 with 31" tires and no O/D that seems screwy to me.
They are 100% the reason I bought the truck.
Martin
My dd with the 4.10s with a 700 and 33s is too high.4.10:1 is the ratio that I would run in that combination, too. It's the running 4.56:1 with 31" tires and no O/D that seems screwy to me.![]()
Do you have a project lined up for them, or are they just in inventory?
Or you could just fix that rig up, since it seems to be mostly functional...
See you don't get it. The 6.2 700 and 37" will be getting 5.13s.
Not sure how anything pulls 3.08s and a .70 overdrive. That is a 2.15 equivalent final drive ratio.
Is the data plate on the door?
Martin
I swapped drivers doors.
Martin
So what happened?
