WL: Crusty 1985 K20.
I don't have dodge hubs or a dana 60 but I'm running DRW 9/16" studs all the way around on my rig to get the longest stud possible for the wheels I used to have. Should just need to bore out the dodge stud holes to fit some chevy studs, right?
I got my hubs turned down. What studs do I need to pick up? Should I reuse the Dodge rotors?
Martin
14 bolt studs...the long ones:
  • Dorman part number: 610-189
They would have an OD of .658", i then used an 21/32" endmill or drill to open up the hub holes. That gives you roughly .0015" press fit which is perfect.
Are wheel bearings, seals, and such the same between Dodge and Chevrolet?
Martin
Some parts came in the mail.
I spent all morning mowing road ditches though.
Martin
There is a few big Jeep runs coming up in Missouri, I'm trying to do the maiden voyage of mine and the other project at either the late August or late September night runs there. Night wheeling is cool.
Usually a good time. They bought some private property this year so you have to buy a $25 membership to get in. Poker run, band and dance on Saturday.
Oh. Figured you knew about all of them. Ebke always gets mad about "no invite" to the river.
