So I have not driven this much of late, as I have three children under four to haul around. Apparently they need car seats and such.
To make matters worse, my Dana 60 hubs were screwed up by me (used too big of a drill bit, per bad advice) which put the Dana 60 install on the back burner. The GM 10 bolt was holding up, but developed some very bad death wobble. So it mostly has just sat.
Today’s beautiful weather got me thinking I should just see what the issue is.
My toe rod end is shot. It is the long tie Rod end. I cobbled it back together to see if that would eliminate the death wobble.
Yes, that is a square REA pole washer under the dust cap to shim out the slack……
Took it for a drive, and that mostly took care of it.
When I returned home, I of course had to park like a jack ass.
I also found where some of my chickens were hiding eggs.
Martin
