So a little update on this. I fixed it.
You know how all the worst disasters are just a whole bunch of little things gone wrong and then boom everything blows up. Well thats basically what the problem was.
Bad DLE on the pitman arm, one loose TRE, drag link and tie rod not adjusted quite right, steering box way loose, not the bolts holding it on just needed to tighten down the adjustor nut some.
I think the fact it stopped turning left had to do with the TRE I sheered off that day.
Tomorrow off the jackstands and go for a test drive but it sure turns good on the jackstands
