Work truck pic........
dontoe
3/4 ton status
Hickory, N.C.
Needed to "strech" the building about six inches. My fault, I was up on the scaffolding when we put it up, and didn't notice it was off the mark by about 6 inches.
So, did it work? When are you going to be available to put mine up? :haha: That looks super sweet:bow: .
Oh yeah, moved the whole friggin thing the six inches I needed. Had to winch on all four corners though. Hellious noises coming from it as it stretched and finally gave!!! It's anchored down now!!! Two 1/2 inch anchors at each corner. Put a couple more, spread out tomorrow. The trough gets filled with concrete when I have all the bolts tightened down. Let's see, that's about 3,800 bolts to tighten, IIRC.:eek1:
Everyone remain calm... This is an official highjacking... Get back to your seats, sit down, shut up and hang on...
Ok really, I would like to know if the winch mount that you have on the front of that truck is available anywhere. So if ANYONE knows where I can get this simple and clean style front winch mount for my 89 Sub I would really appreciate it.
Thanks
Now, back to your regularly scheduled thread. :D
Thanks
Don has a ready welder now:D . I bet he could meet up and do some crazy ninja welding without you even knowing.:haha:
Thanks
Looks like it's a older Warn Multi-mount Portable Winch Mounting System using a Warn M8000, there is a reciever that is mounted in the bumper.....
Thanks
It's just the standard Warn receiver style mount. I made a through the bumper receiver mount so it was up high enough to clear most stuff. The receiver fabrication process (easy) is in the garage forum, the winch is as I said a standard Warn multi-mount, I think they call 'em. Oh, you can hide the mount if ya put mount a tag in front of it!
Mine was "off" a bit too...
My quonset was "leaning" after I got all the arches bolted together!..I had to tweak it plumb with my truck too,but I had no winch other than a boat winch I used to lift the arches up with, using a 4x4 wood post 16' high I rigged to attach into my trailer hitch receiver,so I just chained my truck to it and drove slowly forward!..
That "hellacious" noise you described I remember very wel--like chalk on a blackboard ,on steriods!..l...should have heard mine when my Ford bucket loader slammed into the arches as I was pulling it out of the mud with my truck!..I thought sure the whole thing was going to collapse!..my neighbors called the cops, and reported an explosion !..:p:
I guess your building is sitting in a "keyway" in the foundation,and is anchored mostly by the cement poured over the arches into the keyway???...I ordered mine with a steel "U" channel peice that bolts to the foundation with 82 half inch anchor bolts!..and I cemented the outside of the arches into the channel..if I was real ambitious,I could unbolt my building and take it with me if I moved,but I think building a new one would be easier..:crazy:
ready welder? like a 110 buzzbox? We have those at work but they never get used because they don't penetrate unless you buy a high capacity cord. Even then your lucky to get 1/4" with a triple pass.
When are they gonna come out with a welder that runs on exhaust fumes?
This 'un (ReadyWelder) uses 1,2 or 3 batteries. I bought an Argon tank for it, but the flux core seems to work better. I haven't had a chance to practice with it much, but Gotlabs may find his rear axle welded to a heavy chain, welded to the nearest massive metal object.
