Maybe you just can't get enough air and you're over fueling. Add a turbo. See if it helps.
Your bad influence. Now pushing me to go propane. Then hmmMaybe you just can't get enough air and you're over fueling. Add a turbo. See if it helps.
. I bet you can't read your plugs with propane?You will not see a difference.This is easy! Didn't have to cut it out to get to it.
Converter in question
Tools & what not used
1/2" spade bit
2" holesaw on an extension
Prying & tapping
Clean up the mess and on to the second oneView attachment 293054
It's put back together and I didn't mesjer, not that I could at the back of the cat. But the exhaust is 2 1/2" OD after the cats.What diameter is that hole that’s left? Looks small.
Hopefully you meant "I will see" right?You will not see a difference.
This CAT is clean.
I have had some really bad ones after the engine running too rich for a while.
Nope.Hopefully you meant "I will see" right?
Just took it for a spin. You are correct. Hey it sounds a little better thoughNope.
This CAT was not restricted so that is not what your problem is.
Just took it for a spin. You are correct. Hey it sounds a little better though![]()
That’s what really matters.
