Wow! 8500 ft. lbs. of torque!!!
Maybe they're including the gears and transmission? :doah:
Nah, that still means a ~1000ft/lb motor ... :haha:
WTF? :dunno:
-- A
Maybe they meant. inches/lb.
haha i like how it says 8500ft/lbs from the 235hp motor...
nice clean truck thouhg.
PLEASE NOTE THE FOLLOWING LISTING CORRECTIONS FOR CLARITY:
  • This truck DOES have A/C. It might need a coolant charge as noted.
  • This is a CREW CAB truck as is correctly shown in the item details, not an "extended cab" type designator as might be implied by the listing text/description.
  • This IS an 8 FOOT BED, but not an "extended bed" - the adjective used in the listing text/description might imply being "longer" than the standard 8 foot bed.
  • There is an extra "zero" in the 8500 foot lbs. torque description stated - it should have read 850 Ft. Lbs.
    mmkay......
    mmkay......
I still think they are too high:rolleyes:
Dik
They must mean a towing capacity of 8500 Lbs.....
That's the only way it might make sense...
Maybe it has the nucular fusion hydro-coupling torque multiplyer only offerd on trucks bought during the lunar eclipse.
Balzer
$9499.00 ?????:screwy: WTF I looked at all the pics and did not see any gold plating anywhere. Just a lot of rust, dents, and cracked dash. Looks like that truck was rode hard and put away wet. But the engine was recently cleaned and it does have a new Walmart battery.:haha:
I can get a 87 4x4 TBI K30/454/NV4500 locally a lot cleaner than that for 3500.
