WTB : DOOR
well 77 the doors changed again, so,
73-76 and 77-87(91)
ive go a couple pass side doors that are good im scrapping, but no driver side ones
good luck
There is a slight difference in doors from 1976. They will work but the door was 1/8 wider. I *think* GM only ran this version for 1 year (Blazer, Jimmy) but I can't remember if it extended to the 77 year or not.
Like I said, it will work but it makes the gap look much smaller than the other door and down the road, door hang will be more of a problem.
I suggest you tell your friend to stay clear of 1976 /shrug
[ QUOTE ]
73-76 and 77-87(91)
good luck
[/ QUOTE ]
73-75 were half doors DUH!
[ QUOTE ]
There is a slight difference in doors from 1976. They will work but the door was 1/8 wider. I *think* GM only ran this version for 1 year (Blazer, Burb) but I can't remember if it extended to the 77 year or not.
[/ QUOTE ]
I had a 1976 Jimmy and used 1977 & 1980 doors on it, no problems!
[ QUOTE ]
[/ QUOTE ]
Yeah, they work and look the same, just the width is different by 1/8 inch. I prefer the 77 an up. The 73 to 76 are just to close to the tub, especially with a twisted tub /forums/images/graemlins/thumb.gif )
[ QUOTE ]
[/ QUOTE ]
Not for Trucks and Suburbans, which will fit on your friends rig just the same...
