WTB: Stock K5/K10/K20 Front U-Bolts
GonicGM
Seacoast New Hampshire
For a rolling yard chassis...useable stock U-bolts per above, if I can get something cheap here, great, alternative is I'll bend threaded rod.
What i.d. of housing tubes you need?
I think I only have the 3" i.d. u-bolts.
Right now, there is a 72-back flat top knuckle Dana 44 with 2.75" tubes. I may yank this axle out to sell and put in a 3" tube axle.
So with that, I will consider both a 2.75" set and a 3.00" set
Not sure if the nuts are still with the u-bolts or not. How's $25 shipped for the u-bolts sound?
This is all four u-bolts including the larger diameter that goes around the cast housing? If so, probably interested in your offer.
Yep, sure are. Haven't checked for nuts yet as I just got home from taking the kids shopping.
