THEMCGUIRE
Status update
When I started this project I made a To-Do list. Added a lot of steps along the way but ended up with 183 steps. 119 are done. 64 steps to go.
Attached pic's show where we are now that we painted the interior with three coats Zero Rust diluted 15% with Zyline. Used about 90% of the gallon. It was 90 degrees when we painted and did not use a good paint gun. Just used a Wagner Control Spray Plus HVLP. I did this because I wanted textured results. My experience using Plasti-Dip in High Temp's taught me that this would happen. While it is not a uniform pebble finish it does have some texture and we are quite pleased with the result.
See closeup of piece of dash, for how it came out this way.
Included pics are overall look from rear, and look of front dash area with new shifter in place.
We had some trouble with the shifter back up lights. There was not much instruction about them in the manual but we then figured that we had to cut the power line TO the backup light switch and send that to the shifter, then from the shifter to the backup lights at the fuse box. This worked fine.
The neutal safey switch and back up lights on this shifter operate by the use of two micro switches on the shifter mechanism. There are three raised metal spots on the shifter that close one micro switch when the shifter is in Park or Neutral. The other switch is closed when it is in reverse. We can now shift through all gears, only start in Park or Neutral. Which was the reason we replaced the column shifter.
We also did a lot of fiberglass bondo on the door jams. As you may know the aftermarket rear panels needed a lot of work. One was 1/8th inch shorter then the other at the front end. (We know this because the inner metal of the rear quarters panels is flush, and tight against the back of the pillar yet the outer metal would not reach around the pillar into the door jamb.)
Look of passenger door seam after fiberglass bondo. I hope the irregularities will not be so noticeable after painting.
I still have the problem with the concave bend in the doors from when I was trying to bring out the tops. I pushed in the middle of the door. I now know that middle meant edge of door between top and bottom not exact middle of the door.
I suspect I need special tools to get these bends out because I cannot find a leverage point to pry against.
http://coloradok5.com/forums/attachment.php?attachmentid=148528&d=1375635361
Would appreciate suggestions on how to get those bends out.
