So my blazer has been pulling to the right for a while. It pulled just a little, but all the time.
Then my brakes started to squeel a bit and it would pull harder while braking. So i took a look at the brakes, everything looked O.K. until I stuck a dial indicator on the rotor and turned it. Off by 6 or 7 thousandths of an inch. So my rotor is warped, right?
Bought a new rotor, and it's off by 13 thousandths??! Crappy rotor?
So I took the rotor back off, wire wheeled the back of the hub, cleaned the rotor and reassembled. Still of by 11 thousandths.
Then I match marked the rotor and hub, took the rotor off, and spun it 180 degrees on the hub.
THe high spot is following the same spot on the hub - ?? The rotor appears to have nothing to do with it.
Can the backside of the hub warp?
I pulled off the driver's side wheel just to stick the dial indicator on that rotor for comparison... within 1 thousandth of an inch.
So it is possible for the rotor to spin true to the spindle...
I have a couple extra hubs laying around so I mounted one up with a different (used) set of wheel bearings. It did not have a rotor on it, so I measured the back of the hub, on the rotor mounting surface. This one was off by 2 or 3 thousandths on the hub...
What's going on here?
I want my hub and rotor to spin straight and true so I can be sure nothing is dragging and causing/ contributing to the pull to the right side...
Any thoughts here?
Any thoughts here?
