blazeonchevy
well put
well putchevy wrangler said:the PO of my truck had blocks on front!!!! he was a total retard when i took all that crap off(was on for like forever)the front springs were at a really bad negative arc and the blocks were rotted out!!! friggin retards!!!
We had a tard diwn in Mcminnville who had a 65 chevy 4x4 truck with 4 inch blocks up front and stacked 3" and 2" blocks in back and he made his longer u bolts out of 3/4 all threadchevy wrangler said:the PO of my truck had blocks on front!!!! he was a total retard when i took all that crap off(was on for like forever)the front springs were at a really bad negative arc and the blocks were rotted out!!! friggin retards!!!
. I kid you not ! One of my old toyota 4x4's had a home made body lift ( I didn't make it
)made from large flat washers welded to a 3" long peice of 2" dom 1/4 wall tubing . At least it had grade 8 bolts . I have a 71 chevy 4x4 sitting in my back yard thats wrecked and belongs to a buddy . It's got 4 " blocks stacked with 2 1/2 " traction / lift bars under the rear springs
. to make matters worse it's got those same 2 1/2 inch traction / lift bars up under the front springs
.Brians89K5 said:maybe they are desinged to slip over the original body mount and that is to keep it centered? Could work that way, I would trust it though. I once used hockey pucks for a 1 inch body lift. lol. They worked out pretty good but that was back when I was 15 and still learning whats what.
~Brian
