WTT: Dana 60/70 Combo for Rockwells
mikey_d05
1 ton status
Minnesota
I have a D60/D70 set out of a '79 F350 dually. I do not know the gear ratio yet but the truck had a 351 if that helps at all.
I'm looking to trade them for a set of u-joint steering Rockwells. Will add a little cash on top of that if neccessary.
I can do palleting and shipping and the axles will be shipped from Little Rock, Iowa.
You want a pair of steer Rockwell's or 1 steer and one rear? The front isn't DRW is it cause there wasn't any DRW 79's :confused:. I could use them and may be able to come up with some Rockwells. You have an outright sellling price??
I want two steering axles. I guess the truck might have been a '78 then. It's a long story but I know the front has dually hubs on it. I won't be able to check the rear until next weekend.
I'd really like to trade to avoid having to sell this set, and then source rockwells and arrange all of that. However, I could probably do $1200 + shipping for both axles if you can't find a couple of rocks.
Definately have 32.5" pad width? I should have specifyed 78'/79' weren't DRW stock. Probably someone put DRW hubs on it.
Replyed to PM.
The axles aren't currently in my posession, a guy is using them as a down payment on buying my wheeling rig. I'm going to pick them up next weekend so I'll be able to answer any and all questions by then.
EDIT: Also, that would make sense, since I'm pretty sure that I remember the for sale thread for the rig these axles came from and it claimed the truck was converted to DRW.
OK I'll see if I can come up with anything. How soon you needing them?
As soon as you need the 60 and 70. ;)
There are no plans for the rocks until April or May, so I'm pretty flexible.
I need the D60 about as bad as I need 2 wheelin rigs :haha:,but I buy all the 78'/79's I can. Thinking about doing a Solid Axle swap on my D-Max :D.
Bump, I'll give it until next Monday and then I'm just gonna put these up for sale to fund buying the Rockwells.
I haven't even left the ranch since I PM's ya last :( but when I do I'll see what I find. Go ahead and do whatever you have planned though,if I find something I'll PM ya.
