crazedyak
That Guy
I bought a 1987 K5 at the beginning of the month, but due to work, it's pretty much sat in the yard waiting on me. I've always wanted one, and finally decided to just do it. Interior upholstry seems good. Exterior has some small paint spots where the clearcoat has started peeling.
Things I have noticed so far.
1) I bought from the Original Owner. It has sat in his yard for a few years.
2) 148,000 miles
3) Rocker panel and Floor Pan near the E-Brake on Driver side is pretty much rusted out.
4) Rocker Panel on Passenger side has two small paint bubbles, the size of nickels, that will turn out to be rust no doubt
5) There is an oil leak somewhere near the oil pan. I have not crawled under there enough to dig top find the leak
6) The exhaust seems to be running a little rich. While at idle I see white smoke for about 1-2 seconds from the exhaust, but it does not get worse when I rev up the RPM's
7) There is definitely a Power Steering Leak somehwhere, and I'm hoping it's just a bad o-ring in a hose.
8) Fuel gauge is showing way past Full. Pretty sure that the Fuel Sending Unit is bad, as it is probably the original one.
9) Power door locks don't do anything. I don't even hear a relay try to actuate the locks. I suspect the relay to be bad, but don't have a clue where it even is.
What I have done so far (very cosmetic right now)
1) Replaced the two interior some light bulbs and covers
2) Replaced the License Plate Bulb and Cover
3) Replaced the Horn Relay and Fixed one horn (bad ground) and bought a new replacement for the other horn which proved broken
4) Replaced the A/C Blower Motor Relay
5) Bought Driver Side Floor Pan, and Rocker Panel repair kit from LMC, now just gotta find the time to start.
2) 148,000 miles
