yee ha!! Blazer is drivable again, sort of.
I'm going to be having that one fixed a little this winter, and I intend to ask about small runs. I need better zippers and some rips fixed. Not rips, but spots where the stitching popped over the years.
I really like CanBack's design, but for $1300... I don't think so. :mad:
I am in the same boat. I know that if I create the rails I want, I can easily have a marine shop create one for around $500, which wouldn't be bad.
Apparently, STC used what looks like plain-Jane conduit to me. :D And the brackets aren't much to make either. DO EEEEETTTT
That's about 25min away... pretty short trail, but it ends at the beginning of another one that is a bit harder. Without a winch in your party, there is no getting past a 6' ledge in the middle of it... and I'm not sure I can fit through the tight snake run at the end of it either... but the first trail, I can do. :D
There's a dry waterfall at the end that I need some rocker protection to try.. .but it's got a bypass. :D
I can crawl that ledge....(its called waynes world) without a winch:D You should have let me know you were going out there:(
I was talking about the Eagle's Nest. :D
We kind of took off on a quick run. When I get back, Nov. 1, I'm going out again damnit. Plan on it! :D
Make sure you PM me before you go........I havent hit that trail in a few months, and would like to go before it snows.
Whish I could see the pictures:o Maybe you should put them up on the rme so I can see them without spending any money, since I don't have any.
