fireplug
SierraClassic said:I'd run dual red tops with a diesel... As mentioned, deep cycle batteries last a lot longer with smaller loads on them, but can't put out nearly as much amperage as a conventional battery.
Diesels are very high compression engines, which are hard to turn over, but also need to be spun relatively fast to start. That means you need to draw a lot of amperage really fast, which means you need two batteries connected in parallel (positive to positive, negative to negative) which keeps it 12 volts, but allows for a lot more amperage for the starter to draw from.
Right. Forgot about the compression aspect. I was trying to compare, spark with glow plugs, and that didn't compute to higher draw.
once these current ones die
