Sold York OBA System
FOR MUD
Clayton Del
I have had this system on my rig since about 07. Maybe has an hour or two over run time. Everything runs fine. The only reason I'm selling it is I now have a Co2 tank and I might run a 12v pump in the future.
I'm going to throw this out there for $300.00 + shipping. Figure on 60 - 70lbs and I will be using UPS.
The pump is a York long stroke, 210 series. It was new when I put it on. I did the sheet metal mod to slow the oil bypassing. The clutch was new too.
The tank is a 2.5 gallon tank.
Manifold with gauge shut off switch ( Set to 120psi ) Over pressure valve.
Oil/water seperator
Engine mount, 1986 SBC
Outlet hose and belt
The only thing you will need is a wire going from a switch to the pressure switch and one running from that to the clutch.
Let me know if you need any other info.
Dang! This is EXACTLY the setup I want for my 86!!! Why do I have to be broke right now?!?!?!? Got any pics of how it sat mounted up on the engine?
