Zero Rate / EZ Inch and Perch ?
AJs72K5
blub-blub-blub-blub
Central Tx
I searched around and haven't seen anything on this.... can you use a zero rate in combination with one of DIY4X's or Ruffstuff's perches to move the axle even further than 1.5 inch? The application would be a 14FF with a shackle flip and I'm trying to see if I could move the axle back an additional inch from the 1.5 inch I'm already getting out of the perch. For example, use the offset hole in the zero rate AND the offset hole in the perch? Does that get unstable? Is anyone doing this?
I don't think it would be very good to do it that way. The axle would not have enough direct support IMO.
Kinda what I figured...but thought I'd run it by everyone.
