Flamin' Fast
Registered Member
i just finished lifting the front of my k20. ive got 6 inch springs with zero rates so 7 inches total. and i need to lift the rear a true 6 inches to get it level. i was planning on just running blocks for now. but it will only be a temporary thing. i just need to get this truck on the road. do they make a six inch lift block? or could i run a slightly smaller block and a zero rate? is it even safe to run a zero rate with blocks?
, he is looking to lift the rear to match the 6" springs and 1" zero rate he has on the front.
