Zero-rate ?
noJeepshere
I Drove Trains!
Layton, UT
Does anyone know if the zero-rate add-a-leaves can be used on later model trucks? I want to lift the rear of my 99 Yukon and am considering these if they will work. Thanks for any input.
Yes. Proud to say I used a set on my '92 way back in '00 or so. Stephen didn't know if they'd work or not but said he didn't see why they wouldn't.
Heck, back then they had no offset in them.
They'll fit just about anything with a 2.5" wide leaf spring. I used them in Fords and friends used them in Dodges.
Glad to do it. Fond memories of another time. Did the install at the MCAS Miramar Auto Hobby Shop with my dad who was visiting me while I was stationed there. Good times.
They really work on anything, you just have to check the spring width and have enough U-bolt length. The center pin diameter can be a problem sometimes but it's rarely a huge deal.
