Pictures? Please...So the spring pack is not centered on the perch and you drilled a hole?
noahrob said:OK, I think I got it, that little drawing helped out a ton, thanks. One more question, wouldn't the center pins need to be cut real short and the through bolts (little silver ones in the picture) need to be longer, assuming the leaf pack is pretty thinck?
