Zimmers 06 LLY
Discussion in '1982-Present GM Diesel' started by 76zimmer, Jan 7, 2020.
  1. BadDog
    Feb 24, 2001
    7,972
    196
    Phoenix, AZ
    Build(s):
    Heck, I'm still running my chipped LB7 bought new in late Dec '02 (smoking deal, one of the last '02s). Fully loaded CC 4x4 2500HD for $35k all-in and out the door. So far, it's been a good 'un. First time I ever bought what I really wanted instead of just what I needed. And I've never been happier with a vehicle in my life.
    I simply can't stand the price on what the new ones cost. $75k+ is just too damn much for a truck period. And if I can't pay it off in a year, I'm not doing a deal. So that leaves me with my '02 until it or I die I guess. Good thing I'm happy with it.
    GWeakland620, 76zimmer and max 02 like this.
  2. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    25,759
    7,368
    Kzoo, Mi
    Build(s):
    Dean has racked up the kilometers on his 02 as well. Over 500km I think right Dean?
    They have great longevity if taken care of.
    max 02 likes this.
  3. max 02
    max 02 N.E.D. Premium Member GMOTM Winner
    Sep 29, 2009
    10,733
    4,433
    Clive Alberta Canada
    Build(s):
    Yeah Mine and Colby’s both have over 500.
    76zimmer and GWeakland620 like this.
  4. GWeakland620
    GWeakland620 THE CK5 Crayon Eater Premium Member GMOTM Winner
    Sep 15, 2010
    14,610
    13,546
    Toe-peek-ugh, KS
    Build(s):
    5
    Way to go Dean! :eek::waytogo:
    max 02 likes this.
  5. max 02
    Sep 29, 2009
    10,733
    4,433
    Build(s):
    Can’t say they have been trouble free. We have done a lot of work on Colby’s, but it was a 1000.00 dollar farm truck when we got it. Mine has been really good. We bought it new. One set of injectors at 369 that i’m not sure it even needed then. Does need another one now because of high return rate on one, but it still runs like a top and no smoke.
    The thing I like about them is they are easy to work on compared to the newer trucks and no emissions!
  6. 76zimmer
    Nov 14, 2005
    25,759
    7,368
    Kzoo, Mi
    Build(s):
    That was a big reason I wanted 07 or older!
    max 02 and GWeakland620 like this.
  7. BadDog
    Feb 24, 2001
    7,972
    196
    Phoenix, AZ
    Build(s):
    Yes, another VERY good reason to keep what I've got!
    GWeakland620 and max 02 like this.
  8. max 02
    Sep 29, 2009
    10,733
    4,433
    Build(s):
    Plus you live in AZ. I wish we had no rust issues...that is the death of many around here.
    76zimmer likes this.
  9. beags86
    beags86 Eastbound and Down Premium Member
    Jan 18, 2011
    11,665
    15,001
    Northern Illinois
    Build(s):
    3
    So that's like 310,xxx bald eagles?
    76zimmer, max 02 and GWeakland620 like this.
  10. max 02
    Sep 29, 2009
    10,733
    4,433
    Build(s):
    Indeed Brian. :D
    beags86 and 76zimmer like this.
  11. 76zimmer
    Nov 14, 2005
    25,759
    7,368
    Kzoo, Mi
    Build(s):
    Thoughts on what type of coolant to use? I know it calls for dexcool longlife, but Dean I know a few yrs ago you did the extensive flush recommended by Luke, and wondered what that involved and what you used then, and was it a brand Luke recommended? Doesnt the long life turn corrosive after like 5-6 years? I cant find a record of when mine has been changed.
  12. max 02
    Sep 29, 2009
    10,733
    4,433
    Build(s):
    I just dumped it flushed with a garden hose ,refilled with Dexcool. I did test the ph on the old fluid and it was still Ok. Luke did say that test was SOSO but he also said send it! Lol!
    Colby’s engine has been apart three times since we have had it and I can’t see anything that looks like corrosion on the heads or anything else. Buddy Lorne says run Dex.
    The resson I was concerned was that Russel had a Lb7 that was corroded. He bought that engine used and who knows what was in it?
  13. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    13,329
    5,082
    Pinckney, MI
    Build(s):
    3
    As long as you dont leave it in there forever its fine.
  14. 76zimmer
    Nov 14, 2005
    25,759
    7,368
    Kzoo, Mi
    Build(s):
    It could be the original, i have no proof otherwise??
    Ill try to do a pH check on it.
  15. shady
    shady 1 ton status Premium Member
    Jul 31, 2010
    10,171
    5,663
    iowa
    Build(s):
    6
    That's something almost nobody remembers to change.
  16. max 02
    Sep 29, 2009
    10,733
    4,433
    Build(s):
    Whenever they did injectors it would have been dumped out I would think. LB7 You have to for sure.
    LLY LBZ and so on maybe not all of it but some anyway.
  17. 76zimmer
    Nov 14, 2005
    25,759
    7,368
    Kzoo, Mi
    Build(s):
    pH is 8.0, a bit high of neutral ,but not bad. Color was a dull pink, but not dirty looking.
    Level was a bit low.
    Truck is fun the more I drive it.
    Noticed when its cold, just a fraction of a second before it shifts at 1-2-3 it seems to take away power, but not once its warmed up....shifts are real good, but just seems like this shouldn't be with an Allison?
    GWeakland620 likes this.
  18. 76zimmer
    Nov 14, 2005
    25,759
    7,368
    Kzoo, Mi
    Build(s):
    I was told by the salesman, it had injectors changed, but after seeing the records, I think that may have been glowplugs?
  19. max 02
    Sep 29, 2009
    10,733
    4,433
    Build(s):
    Normal... they don’t shift smoothly till they are warm. Mine never has.
    GWeakland620 and 76zimmer like this.
  20. 76zimmer
    Nov 14, 2005
    25,759
    7,368
    Kzoo, Mi
    Build(s):
    Good to hear!
