andyblack
Registered Loser
Wow that's a lot different than your normal terrain. Which do you like better? Didn't anyone tell your dog not to stack rocks on the trail?
I like wilderness too but there's not much of it around anymore. Not that can be legally traversed anyway.![]()
Oh yea, I plan to return to Big Bear, crab flats campground on Sept. 17th. Chime in or shoot me a PM if you want to hit a trail or meet & greet.
I plan to do that. thanks.That's the same thing that happened to me. They kept backing out after I tightened them, so I wound up putting in slightly longer bolts with nuts on the back side and torquing them down pretty good. No issues since, you might wanna keep it in mind.
Right on Mike, It's a plan. I still have your phone number too.That sounds very doable for me!
... So I went to the junkyard today and saw 14 bolt axles for $85! I almost bought some. I didn't see any dana 60 fronts, what vehicle do they typically come on?
There was an 8 lug 10 bolt front with the diff cover egg shaped like a dana 60- paired with a 14 bff rear. I guess that would be a 3/4 ton set up- right?
Next weekend all parts are 50% off.
I'm thinking low budget build![]()
sounds like Ill be making a trip out that way next week!I plan to do that. thanks.
he found me a very cheap, very clean 14 bolt FF!
Get that rig ready so we can go wheelin!
