andyblack
Registered Loser
Mmmmmm....... burritos.....
The front is freakin sweet! When I went on the mid build run to meet SBD we did some fast runs down sandy washes with whoops.
Even with the old junky shocks it ate up the bumps and delivered a smooth ride.
I even caught some air at one point and landed smooth.
Glad to hear she is now I true dune runner!!!
Maybe one day you will make it out here, or ill make it out there for a weekend of sand slingin!!!
springs and the shocks were listed to work specifically for a 4" lift it should be fine. View attachment 153348
Calendar Truck
A cobbled together hacked up mostly stock Junkyard JIMMY on 10 bolts made it in the calendar.
A rig so sweet that it gets awarded 12 months instead of a measly one.
A GM of the year award if you will be so bold.
It hasn't gone to my head at all...![]()
Well okey dokey then.
I didn't measure the front shocks and axle travel before installing them. I know, Better men would have but I figured since I ordered 4" "soft-ride"springs and the shocks were listed to work specifically for a 4" lift it should be fine.
Well it was like an itch in my brain that I couldn't scratch so I just had to go out and check.
This photo is my shock disconnected and axle at full droop
The shock and axle bottom out at the same time. I would feel better if I had another inch or 2 to spare on the shock but I don't. I could move the bottom mount up an inch or so but I don't know...
I may regret it but I think I'm just gonna call it done for meow.
I'll drink about it and decide later.
