Well, about that. All the power steering fluid has disappeared somewhere, so all you can hear in other videos is the pump whining. I’ll get another video when we get home and get some fluid in it.
Truck sounds great! What size and layout did you wind up going with on the exhaust? I remember you debating 3" earlier but couldn't remember if you stuck with that or what the routing was (x-pipe, h-pipe, or straight pipes).
Btw, your driveway is steep as sheet!
Well as long as it's between 5 and 8, and the top is tilted back (in case negative and positive is confusing) your angle should be good.Clarification: It is +8* measuring from the top of the inner C and top of the knuckle on the king pin cap.
Lookin good!
You know, we've got a reservation at Stoney Lonesome we need to burn up this fall...![]()
