I was wrong, it was a hidden vacuum leak.Neighbor brought home a vacuum tester so I hooked it up to the trans modulator, that was fine, then the distributor. Bingo. Also tested my vacuum gauge
Distributor canister was just letting air suck through, so it caused a vacuum leak and didn't advance the timing. It runs a whole lot better at idle, and starts right up again.
Still no secondaries opening. I need to figure out if the linkage to the throttle plates aren't opening enough, or if my small bit of vacuum issues are the cause.
I have 15 on the mannifold, on the fitting behind the carb that screws into the mannifold, that I use for the transmission. I only have 10 on the bottom port of the carb. So I'm wondering if I have issues from rebuilding the carb.a
What carb? Adjust the airscrews? Timing? That cam should have 20+ hgs of vac. If it is a qjet first fix the vac leaks then you can adjust the air doors to open better but my guess they are opening but you don't feel the bog (what most people think is the 4 barrel opening).
