1 piece or 2 ?
Wes Harden
1 ton status
Staff member
Moderator
Solutions
2
Lake Havasu City AZ
My k20 Burb with 4" lift, has a 2 piece rear drive shaft. I shortened/balanced the short fixed half after the 700r4 trans plant. I have adjusted the center support bearing by shimming it various heights. I have drive shaft vibrations at various speeds.
In the near future ( i hope) I will be installing 4" shackle flip and 56" stock rear springs. I know the slip yoke on rear half of the shaft is barely long enough for the lift w/o wheeling. I expect to have a new shaft made when I do the flip.
The question is 1 piece or stay with the 2 piece ? what is the longest 1 piece shaft advisable. I can and probably adjust pinion angle at same time. If I can do a 1 piece shaft should it be CV ?
What are the CC long beds using for a rear drive shaft?
I’ve tried both in the k10, and went with the one piece due to the change in the angle of the intermediate shaft after the lift. I broke the first single, and put the old 2 piece back in. It was very clear that the one piece ran smoother
Right now I’m back to the single with a CV. From joint centerlines it is 58”. It’s running 13-50 and .1875” wall
I also used a one piece on my longbed. It’s a 1350 CV and around 65” IIRC.
I'd stay with one peice if I could...I had a one peice in both of my 79 longbeds, they are one peice from the factory. 131.5" wb, and burbs are 129"...iirc.
Wonder what year the factory changed driveshafts. Mine was a factory 2 piece on the longbed
In my opinion, it depends on what you are using the vehicle for. I have a 2 piece in the crew cab. I like it because I can move the support bearing to get the drive shaft angle I want. I moved my support bearing back so the drive shaft angle was steeper and so far it has gone longer without needing re-tubed.
If I wasn't worried about rock damage, I would be more open to a 1 piece shaft in a long bed or suburban. My 2 piece shaft has a 1410 CV at the support bearing. High Angle Driveline built it for me. I still need to work on the angles after doing the 4l80e/Magnum install they are a little wonky. It does pick up a slight vibration 48-53 mph.
I don't think 1 piece is even an option with a CCLWB. Maybe if you can afford aluminum or carbon fiber you could do it.
Thanks guys, I think the 1 piece with a cv at the tcase is best choice. I don't plan on any lvl 5 or higher trails for this truck. I an aiming for smooth soft ride as possible and still be able to some trails.
My suburban is a 1 piece, I'm also running a 4 inch shackle flip and stock 56's. It runs down the road fine, with the stock 2 joint drive shaft. I set the angle and burned in my perches after the lift.
I was under the burb today, and the 14bff pinion is pointed right at the out put shaft on the t case. So I am going to go with a cv 1 piece drive shaft. I need to switch from rear out put yoke to a flange.
Is this the correct flange for rear output np205 ( I believe my t case is a 72) https://www.offroaddesign.com/1350-...ft-2-pilot-for-aftermarket-cv-driveshaft.html
If it is, I will order it install measure and order my drive shaft.
Depends on what design head on the c/v .
Have you looked at ford superduty front shafts ? There 1350 and cheep used . Get one for like a 05-up newer . They tame a specific flange you can get from HAD / ORD / others .
I looked at them everyday before I retired. Not sure it will be long enough. I know I measured it once forgot to note it down. I'm having shaft made so pilot size will match.
cheeper to retube the shaft . but you choice i was just tossing out the idea . last one i got shipped from cali rust free was under 100 bucks .
I am looking at 63" with the current shaft. So what out put shaft flange would I use to put a retubed Super Duty shaft on the rear of my np205 ?
It mates to a flat flange. My 205 has the flat flange on both front and rear outputs with the 2 patterns, but is not stock.
Pic of front Super Duty shaft...
yeah I have seen them in their native environment even r&r'd more than a few. Our fleet had at least 130 2011 f250 sd 4x4's probably another 100 f350 f450 and 50ish f550 .
I am mostly looking for flange info to fit the rear out put of a 1972 np205, 1 that will work with the SD shaft that will save me some money over a new complete custom shaft.
Still looking for a flange to use with the super duty shaft. The ORD flange has all threaded holes. The SD shaft flange has the threads so will need a flange with plain holes the correct spacing. I can't seem to find the pilot hole size or the bolt circle for the SD shaft. Torque king has some info, a lot actually, but not application specific.
any one know if this will work with sd front shaft ?
If i recall the m1009 build i did in my sig line i picked jesse @ HIGH ANGLE DRIVELINE cause his flange can be used later for driveline ebrake option .
Yeah you did use HAD for the flange. I think PM flange is the same Paradise & Auburn are 20-30 minutes away from each other.
I guess I just get a SD shaft and measure be I order a flange
