1 ton C/K30/3500 parking brake cables
thatK30guy
1 ton status
Brand spanking new. Fits the '83 and newer 14FF's with push-in style ends. Pasenger side is longer than the driver side.
$30 for the pair.
Factory length but will work with mild lifts just fine. I'd say anything over 6" lift would be stretching the cables slightly.
You can modify the bracket under the frame by lowering it a bit. Just remove the rivets and put some spacers between the frame and bracket to drop it down.
I don't see why not. Just a matter of fabbing the mounting point on the axle tube somewhere and getting the rest to fit/work.
Possibly interested. Can you measure the length of both?
The driver side (shorter one) is 54" overall length and 36" from clip to clip.
Passenger side (long one) is 78" overall and 57" clip to clip.
do you know if these were made for a short bed or long bed?
The flex lines won't matter if they fit a SWB or LWB. The mounting points are the same distance and locations between either truck.
If you have a 14FF, and an '83 or newer, these cables will fit. '82 and older cables have bolt-on ends at the backing plate side and both cables are equal length.
sorry bout that guys. Thats the second numbscull post I made today! I gotta start getting my coffee before checking my email.:doah:
Nope. These cables are all I have as far as parts for a K30 go. I do have what you're asking about but they're in complete trucks.
