Bending center pins means you're not torquing and re-torquing the U-bolts properly. Axle wrap may very well be an issue, but if you can't get the right hardware in there and torque properly it will fail again with the anti-wrap installed. What U-bolts are you using and torque cycle?
The anti-wrap kits don't fit any particular axle exactly on purpose. If you have no fab ability, you have no business welding on your suspension.
This is OK because a rear 10-bolt with BBC and oversize tires will fail at some point and you can move the anti-wrap to the larger rear axle. Less work to swap the axle now, though.
