12 bolt posi rebuild
lukerz
Western Mass
Has anyone ever done a 12-bolt posi rebuild ???
Lukers
83 K10 from 76 K5 & 83 C10
Th350 Np203 355 CID
31 X 10.5
Plan on 2" body lift
I am wondering if I should purchsae a 12 bolt posi that needs a rebuild for $50? or just weld my open carrier?
Lukers
Th350 Np203 355 CID
31 X 10.5
Depends what's screwed in the the posi rear... just the posi unit? Or does it need all the bearing and a R&P too? Also if it is a stock gov-lok I know I have heard stories of them scattering parts and screwing the whole rearend... then some just don't function anymore. tRusty has the Lincoln Locker (welded spiders) going and seems to like it... maybe give him a PM. I'm sure he'd be glad to help out w/ the LL questions you may have.
-Mikey
1987 Chevy K5 Blazer- 350 TBI
<A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
If it is the Eaton Possi, with four springs, buy it and rebuild it with the new carbon fiber clutches, and the 800
pound pre-load springs. If its a Gov-Lock Eaton Possi, have them pay you 50 to take it off their hands !
Good luck
P.S. its gonna be old if its and original Eaton Possi with four springs, Tip have the part/peices magnfulxed before
you rebuilt it.
Do you have an opinion about a EZ lockers made by tractech? This would be an easy install right? I am cheap and want to set up for better traction.
Lukers
Th350 Np203 355 CID
31 X 10.5
