12 inch lift crossover doubler gears diy4x
Might be interested in the studs, depending on what they are, I need some 9/16 studs that will fit a 14bff that are slightly longer and probably the same for a 60f. Also is the yellow guy with the yoke a slip yoke eliminator?
Sorry, one more question, can you measure how long they are? I'm assuming you had these to go with the spacers I bought from you, so they should work, just want to double check with a tape measure.
Thanks man
Still got the gears? are they still setup in the housings? I may be around there this weekend and could pick them up. Also the pinion guard ill take.
