14 bolt FF 4.10s Wanted in Northern CA
TopOff
Folsom, ca
14 bolt FF axle assembly with 4.10s wanted in North CA
Ideally it will have a Detroit in it, or else open.
Thanks.
LMK
I've got a 14 bolt here in modesto, asking $60. it's complete, but i only know it came out of a 1978 chevy 1ton van. i payed $150 but that was before i found out about CK5 here's the pic check it out and if you like shoot me a pm
Oops sorry. Yah, I am looking for the whole thing. /forums/images/graemlins/laugh.gif
ok, did the measure on the two axles. /forums/images/graemlins/thinking.gif
my truck 14bolt 40 1/2" center to center spring perch
51" inner dust shield to shield
the van 14bolt 50 1/2"
56" inner to inner
over all it's 5" wider and it could be mounted into a truck by adding two new perches at 40 1/2" /forums/images/graemlins/woot.gif
i can't use it cause mine needs a perch located at 47" on center for my 1988 k1500. hope this helps.
There is a guy in OR parting out a 3/4 ton 4x4. That would be a bolt in deal for you and I am even heading to Redding on May 8th and could haul it down. Check the Pacific forum and you will see his thread /forums/images/graemlins/thumb.gif
