Here is some skinny on the disc brake swap.. lots of people have "some info, but not the whole story", here are a few pics of my swap.
The swap is easy, visit my site at concept-customsdotcom, and click on the engine and drivetrain link for some pics of this exact swap. You need to get the right parts. Caliper brackets for a start. Then "THE RIGHT WHEEL STUDS".. everyone I see keeps saying to use the same studs from the rear drum.. WRONG... one more time WRONG. Be prepared to spend some money one just wheel studs... almost $100 for the CORRECT wheel studs. email me if you need info for this, I am actually putting together a full kit that has all the "correct parts." I am happy to supply anyone with the right parts to make the job "perfect." Again, email me or visit my website for direct contact if you would like some advice for this subject. You will need the the HD 3/4 ton front disc brake calipers for the front axle, and regular k10, blazer, suburban, etc. calipers for the rear, this takes care of brake balance problems (provided you don't need the E-brake, more on that later).. the HD calipers are much larger than std calipers, so no proportion valve should be be needed. All parts will maintain GM OEM production requirements, so parts availability is always easy. Make sure to have the rear hub turned before you mount the front rotor to the rear hub, helps to ensure true disc / wheel run out. Now back to the E brake, pre 80 Cadillac El dorado, toronado, and I think, please don't quote me here, but riviera, and some other premium GM, all had the same rear disc brake with e-brake function. Get ready to drop a load of cash for these, even rebuilt from Napa, + the $150 ea core charge. I can actually get these brand new, a little less expensive again, e mail me if you are interested. Most people that have built this setup have used a driveshaft, or T-case e-brake (mostly depends on the T-case 208 or 241, and wether or not you have SYE installed), this method is usually much less expensive.
