As Biltit said, yup...
just save yourself a few headaches, and have the hub turned (same machine that does the brakes) before trying to mount the rotor, and don't paint either before mounting, have the correct studs pressed in, then paint if desired for corrosion resistance. Reason for this, again is runout tolerance. Clean machined surfaces make for long life and low maintainance.
The OEM style replacement rotors have a recess that is smaller than the diameter of the stock wheel studs by about .065 inches, and yes, this is where I made the statement earlier that people are using the wrong studs (SRW and DRW both have the exact same head, knurl and knurl lenght dimensions, only the thread length and tang is different). Almost everywhere I have looked for rotors, the stud recess is very very close to OEM size. I'm not saying that no one makes anything different, there might be some small differences, but more than not, they are all mfg'd to the same spec. It very much appears that the stud has been pressed in all the way, but in fact it is not, and causes the wedge effect, therefore breaking the rotor after a few cycles of get pretty hot, then cool down, retorque lugnuts, heat and cool again.
At least Biltit had the foresight to grind the stud to fit correctly (hopefully you kept it cool during the grinding). Good job! If you don't have the studs already, go to NAPA, they will be able to find studs for you that actually fit without the grinding (not good to heat a Grade 8 treated metal) if they won't take the time, I will. Another point for you Dominic, anything from about 79-86 (K20) will work, I usually order 85, for some very slight mfg differences. Some earlier will work, but in these years you may see interchangeable D44's and GM 10Bolt, pay attention, and do your reasearch.
As mentioned earlier (and very good point to boot), there are 2 versions, pre 87 14bff, rotor behind hub, and then the rotor in front of hub (much easier to service), but these are not so common, because the studs and mtg hardware are metric during the later years, and finding a hub and rotor for the front gets a little harder to find, as these years, you start to see the IFS setups in the 2500's and up.
If you currently have the std caliper on the front, to make for an economy build, clean these up and use them for the rear. Like I said earlier, get the HD 3/4 ton calipers (they are much larger, but the same mounting dimensions) for the front so you don't have to mess with brake balance and proportion valve crap, the front brakes always have more stopping power.
Brackets are the cheap part, DIY, ORD, etc. are all just fine, I kinda like the ruffstuffspecialtiesdotcom brackets, they are the ones I use and would provide with my kits. Not to mention, Dan is happy to talk to you forever about anything, tell him I said Hi.. maybe thats why we get along so well.. anyway
You will need front 8 lug hub assy, and backing plate for the correct mounting, as the OD of the rotors are larger also.
