14 Bolt Ring Gear Code and Inspection Help Needed
ZombieK5
Bucks County, PA
Opened the 14Bolt rearend. Fluid looked the wrong Color but no major metal shavings. There was a sparkle in the fluid but probably because it wasn't changed in awhile.
I was looking for the code engraved on the side to determine the year. This is what I found (photos included)
GM10.5 488X 39X8 9224 10/05
Guessing this means an Oct 2005?
Does the 4.88x mean 4.88 gears? The tin tag on it said 4.10... Really don't want 4.88 gears.
Other photos included. Does anyone see anything of concern??
Yeap 4.88, diff looks changed too.
I didn't see anything alarming in photos, oil color is newish gear oil has greenish tint.
Need to find out what diff that is in case it needs friction modifier in oil.
I'd run a parttern check on it and post the pics.
Try to run the pattern with some resistance on the ring gear. Use the p brake or have a help uses a wrench and hold force against your direction of rotation.
I'm gutting it for full rebuild... Need 4.11 gears. So, any issues can be replaced.
I have the guys at Yukon Gear getting me a parts list and now I guess it will include new gears... Ughhhh.
What should I put in?
Check if need a New carrier, believe break is 410/456 unless these are thick gears which use 410 and down carrier. If you plan for a full locker like a detroit.
Have you ran the numbers to see rpm, I know you like everything to be fresh but having a deeper gear helps with the sucky first gear ratio and overdrive keeps the rpm down on the highway
Honestly, I would learn towards keeping the 4.88's. WIth the 4L80 you just got you'd be at 2500 RPM at 70... might not be awful.
My RPMs were going to be fine with the 4.11s I thought I have. I need to track down the RPM calculator again to do the math one more time.
Well the ~2500rpm at 70 looks correct. That just seems high. Looking at modern Silverado's and they are running ~1500 at 70mph.
Pros V Cons for keeping 4.88s or swapping for lower gears (4.10 = 2190rpm or 3.73 =1995rpm)
Modern drivetrains have two or more gears in the overdrive ratios. unless your main use for this truck is highway running, keep the 4.88’s, everywhere else will be glad you have them!
I DO NOT plan on highway too much but it wouldn't be unexpected. Can't get to the shore here w/o hitting a highway.
How would 2500rpm effect the 4L85e over 100 miles on Hwy?
60rpm is shown to be 2100rpm
I do not plan for this Blazer to be a barn burner. I have a Mustang Cobra for that.
It cost was no option for the same alxe and the same engine and transmission and tires, what would be the ultimate gear ratio.
39x8 = # of teeth on the ring and pinion gears, respectively. The ratio isn't always stamped.
Damn damn damn... I'm reading over this topic online and now I'm considering an ARB. WE have tons of ice here in Philly area and it's the best of both worlds. Open carrier and locker. What's another $1200
If you can go that route they are nice. They add some complexity to the install, because then you need onboard air and all that.... another option would be a Yukon Zip Locker. Same kinda setup
I think it depends on what you prefer and how you plan to drive it.
Do you want steep gears for wheeling and racing, or highway gears for lower RPM on the freeway?
In OD your 4.88s will turn into 3.66 effectively. You also have the benefit with the 4L80E you can lock the converter.
Locking the converter keeps the trans temps down as the converter makes the most heat. The trans won't care what RPM your engine is at on the freeway, no concern there.
However, with just 35" tires and a 496 brodix head EFI big block, it surely don't need 4.88s to be fast.
I find for my needs the 4.10s work well as I can put it on 4 LO and then they are 8.04:1 gears in the sand and still hit 75 MPH in 3rd gear. Low range also keeps my trans temps down. If I had 4.88s I would hit the rev limiter before the race was over in low range. If I put it in high range I lose about a truck length in the short race.
I do want a 4L80E instead of the TH400 as my converter slips and I can't lock it up and no OD puts me approaching 3K at about 70MPH, which means I usually only go 65-68 on the freeway to keep the RPM down. A lockup TH400 is way to expensive so I will likely build a 4L80E for it in the near future, then got OD and lockup, but it weighs another 100 lbs.
As for the ARB locker. I actually prefer a Detroit for what I do. An ARB is either open, or a spool. Which means when its locked, its solid, and when you go to turn it will fight you somewhat. You can disengage it, but not while its already under load. This is magnified in the front axle as I have seen situations where people couldn't turn the steering wheel because the front axle was bound up, and its too late to disengage while its bound up. The detroit does not get bound up like that.
With a Detroit, think of it like a ratchet. Either wheel can go faster than the ring gear, but neither wheel can go slower. So when you turn the outside wheel will disengage and turn faster, and then reengage. I have Detroits front and back. And when I turn in 4WD off-roading it doesn't bind up and want to go straight. I don't like when people say their Detroit locker will "lock" when needed for traction. It's actually the other way around. Its pretty much always locked, and it only unlocks one tire to allow it to go faster, but neither can ever go slower. This also means when you are turning a curve, and you apply throttle, it will reengage the other tire if the inner tire spins at all. Also, if you let off the throttle on a curve, it will go from driving the inner tire to braking on the outer tire. But it's predictable, does it every time.
The downfall is they have a little slop which is required to be able to "reverse" the ratchet when you put it in reverse, but I don't mind it.
I would not drive your rig in winter unless you want it to turn to rust here in the rest belt. But then you do lose the enjoyment in the winter.
Does your carrier have 3 or 4 pins?
It looks like that ring gear is very thick, it might be a special 4.88 gear for a different carrier. Does a 14 bolt even have different carriers like a 10 or 12 bolt? I forgot the answer to that. I haven't opened my 14 bolt other than change the gear oil once since 2003 when I put the Detroit and new seals in it. Now that I said that I will probably brake something.
Saw that during my research but I could not find one for the 14 bolt rear end. They mostly had Dana 60 and a Dana 44 versions.
I will also add to above, is your ring gear wear pattern kind of rough? It looks a little rough to me. Might want to feel it with your fingernail and let us know...
