So the rims are waiting at the shop. Cost me $100 to send them back and order an 8 lug version.
I had already ordered everything to rebuild the front end.
From my understanding I need new different brakes for an 8 lug and a 3/4 ton spindle.
I’ll assume that the 1/2 ton spindle bearings and seals are different?
Appreciate everyone’s input with information. I’m learning a lot about these trucks.
For a street truck with 33’s I should be fine with the stock axles? I’m going to freshen up the rear end with new bearings and replace the yoke with a 10 bolt one. I have the 10 bolt u joints I just purchased also.
. What I should have done is go 8-lug then and there. Very few drawbacks and the brakes work better. I made rear disc brakes for it, welded the tubes to the center, dropped to 4:88 gears, added an anti-wrap bar and an e-locker, so it's not like I can just go grab another axle to replace it. Now I'm collecting parts to make everything 8-lug, like I should have done in the first place.
