I went to the junkyard again yesterday looking for my 14 Bolt SF 6 lug with the more narrow width. I found one and popped the cover off to find out the ratio. Found out it was 41:11 so that meant 3.73 gears. I would like 4.10's in the rear and then change the front's when I drop this one in.
My question, because it's still in the junkyard, I can do some "mixing and Matching" before I actually buy it so......
If I found another 14 bolt SF (6 lug or 8 lug) with a 4.10 gear ratio, can I fairly easily remove the 4.10 and drop it into the narrower 3.73 axle assembly? I know at that point, I would have to set up the rear end with new seals, shims, etc.....but does it make sense to go through this hassle? I think the axle out of the yard will cost me $150 or so. A good deal!
The width is about 65" wms to wms.
