Who here is running 140 with a v belt?
If so how many belts?
What width belt?
Do you get slippage?
What width belt?
Yep. V-belts are so 1917 haha. I have serpentine on everything.as a marine guy, it's V-belts in general.. they just suck compared to a serp setup...... stretch and slippage... when do see serps do either?
I just put a Powermaster on my C10 and it had specific instructions about belt tension. They seemed more concerned about being too loose. IIRC it said the belt should be tight enough it won't slip if you try to rotate the nut on the pulley.
140 amp Powermaster. One belt, no slip.Who here is running 140 with a v belt?
What width belt?
