1480 d60 and 205 yokes
twoslo4five0
3/4 ton status
Living in a dump, VA
does anyone know if someone makes theese??im thinking of making a square front shaft out of d60 stubs but i can find a yoke for either...my 205 is 31 spline btw
Kert is working on a similar set up but he's building a D60 yoke welded to a custom flange.
High angle driveline does sell d60 1480 yokes btw.
As for the t-case yokes, I beleive its gonna be a custom made item. Have you seen the write-up on pirate4x4?
Your front output is 32 spline. I might have a yoke that may work for your T-case. PM me the demensions and I'll check.
PaulC
yep D60 stub to a flange, giving ~42* of angle...good write up on it over on pirate
This is going to sound dumb but do you have a link? The only one I've seen was using D44 parts. :blush:
Thank you sir :bow: That should make for a nice afternoons reading while I'm screwing off at work. :D
Just hope it isn't stouter than your front axle pinion gear or NP205 front output. That would be a cool break broken Dana 60 pinion gear or a 32 spline np205 front output.
PaulC
PaulC
hmmm that sounds like a challenge :D
