Ok, So i posted in the PAD post some quick pictures.
A few weeks ago, i rebuilt my rear drums, and replaced all the bearings.
Timken bearings, packed with a bit of grease, then filled the rear with 75w90 synthetic gear oil. Tipped the axle side to side (1 day each way), and spun the hub a bunch. Bearings should have been well lubed.
So, driving today, it was a bit sluggish, and then started making wierd noises. Pulled over, and the whole assembly had walked about 2 ft from the side of the truck
Quick inspection says the lock nut is broken, but still there. And, I THINK the outer bearing snap ring is still there.
What causes this? Its pouring rain here, but obviously, i'll tear into it soon.
Either snap ring failed, or bearings ran dry and exploded, right?
