daleearnhardt01 said:Alright those 10 bolt drums will work however, the lug holes in the drums are too small for the M14 studs to fit through. Anybody know a place where I can get a stud with a .625 knurl diameter but only 7/16 on the actual stud part?
Can I just drill the holes out in the drums???
Tough call. It looks like I'm going to have to downgrade to 1/2 studs on mine if I want to run my slot mags. There doesn't appear to be any 14mm mag nuts. Otherwise, if I was you, I drill the drums or use 1/2 studs like loafer did on his swap. 7/16 seems too small for me.
is correct, I should have to space the backing plates out aprox a 1/2".
