My point is, it is NOT wrong to re-use the crush sleeve. If it was, I'd venture to say that GM would not have a procedure for it. They have a procedure for it, and it is pretty precise. Most people (no one) that I know follows/uses the GM procedure, myself included. I don't have the proper torque wrench to follow the procedure, or I would have in the past. Out of four times of just guessing and tightening the crush sleeve (after just swapping in random carriers lol) on four different rear ends, only one ended up howling. Still not justifying doing something wrong, just that we seem to get lucky more often than not guessing that it's correct. I also think that re-doing the whole thing properly would be the better approach, with the best approach being to use a spacer and shims like Ratech makes for other rears, but I just called them, and they still don't make one for the 14SF.
Thats why I mentioned checking gear pattern before/after. I don't know why that wouldn't be a valid test, as opposed to measuring the force required to turn the pinion before/after removing the pinion nut.
